KNX - Import/update group adress description - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: KNX - Import/update group adress description (/showthread.php?tid=4802) |
KNX - Import/update group adress description - anve - 02.06.2023 I imported a .knxproj file including the group addresses etc. After this I made some name changes in the KNX-project. No new addresses was added. When I import the new file it doesn't update the description/name of the group adress. Is it possible to do this in some way in the import procedure?
RE: KNX - Import/update group adress description - admin - 05.06.2023 Existing objects are not overwritten. If you want to import these objects again you need to delete them first. RE: KNX - Import/update group adress description - anve - 06.06.2023 (05.06.2023, 06:39)admin Wrote: Existing objects are not overwritten. If you want to import these objects again you need to delete them first. Example: Import 1: GA 1/1/1 = Light 1 ON/OFF Import 2: GA 1/1/1 = Light Office 1 ON/OFF I just want to update the description of the existing objects in the import. If I delete all objects, I have to setup the object properties för each group adress again I guess? RE: KNX - Import/update group adress description - Daniel - 06.06.2023 You can try this. https://forum.logicmachine.net/showthread.php?tid=1621&pid=9888#pid9888 |
