Connect Goodwe Inverter via RS485 Modbus RTU - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Connect Goodwe Inverter via RS485 Modbus RTU (/showthread.php?tid=4805) |
Connect Goodwe Inverter via RS485 Modbus RTU - pioneersteffen - 03.06.2023 Hi @all, I want to connect my Goodwe Inverter to W4K/LM via Modbus RTU. Attached you can find the protocol description. I tried to transfer the document in a Modbus config and performed a Read Test for the “Ipv1” value (pictures attached) but unfortunately it doesn’t work. Can you please help me and give me a hint what I may making wrong? Many thanks for your help! Best Regards Steffen RE: Connect Goodwe Inverter via RS485 Modbus RTU - admin - 05.06.2023 What error do you get when doing read test? RE: Connect Goodwe Inverter via RS485 Modbus RTU - pioneersteffen - 17.06.2023 Hi Admin, many thanks for the response and sorry for my late reply. The failure message is timeout, see picture attached. Any ideas what I need to change? Many thanks for your help! Best regards Steffen RE: Connect Goodwe Inverter via RS485 Modbus RTU - Daniel - 19.06.2023 Make sure RTU settings on the inverter are the same as in W4K, Try changing +/- RE: Connect Goodwe Inverter via RS485 Modbus RTU - pioneersteffen - 22.06.2023 Hi Daniel, I changed +/- and were successful in getting response from the inverter. BUT now I getting a strange behavior of the W4K. It restarts every approximately every 3-4h. It is definitely related to the RS485 connection. Any idea why? I have no resistor oder termination in the RS485 bus and just 2 wires D+/D- connected. Also just the W4K and the Goodwe inverter are on the BUS. Many thanks for your help! Best Regards Steffen RE: Connect Goodwe Inverter via RS485 Modbus RTU - pioneersteffen - 09.07.2023 Hi @all, I found the solution for the issue. After I added 120 ohm resistor termination to the wiring no reset of W4K happened anymore. Best regards Steffen |
