LM5 replace ABB IPR/S 3.1.1 issue - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: LM5 replace ABB IPR/S 3.1.1 issue (/showthread.php?tid=4809) |
LM5 replace ABB IPR/S 3.1.1 issue - richard7 - 06.06.2023 Dear admin, When I try to replace ABB IPR/S 3.1.1 with LM5 using the same parameters. After replacement, LM5 has no respone to action command from other IP interface. ABB IPR/S 3.1.1 parameters are as below: IP address assignment method = Fixed IP address = 192.168.1.105 Subnet = 255.255.255.0 Gateway = 192.168.1.1 BaseT = 100 MBit/s Physical address = 1.1.17 Programming mode = Off Routing multicast = 224.0.23.12 By the way, other IP interface use 2 line address to communicate in KNX system as picture Is there any suggestion to slove this problem? I have total 9 ABB IPR/S 3.1.1 modules needs to be replace by LM5. Thanks a lot. RE: LM5 replace ABB IPR/S 3.1.1 issue - Daniel - 06.06.2023 Drop screenshot from KNX Settings in LM. RE: LM5 replace ABB IPR/S 3.1.1 issue - richard7 - 06.06.2023 During the waiting time, I decided to do factory reset LM5 firstly. Fortunately, after the reset, problem has been solved. Anyhow, thanks very much for your reply. |
