REACTOR and multiple gateways - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Hardware (https://forum.logicmachine.net/forumdisplay.php?fid=12) +--- Thread: REACTOR and multiple gateways (/showthread.php?tid=4831) |
REACTOR and multiple gateways - Frank68 - 14.06.2023 Hi I have a problem with the ETH and GSM network configuration, from a customer I need to send SMS and mail (so I use the reactor SIM) I also need to be able to create firewall rules on the ETH network managed by others so the gateway on the network I need to ensure that requests from remote clients are correctly redirected, I tried and also by configuring the gateway the SIM also receives sms. I can rest assured that in the settings it is recommended not to set the gateway if GSM is used. how can i solve the problem A thousand thanks RE: REACTOR and multiple gateways - admin - 14.06.2023 If 3g/4g is enabled and connected then LM will use this connection for all external requests. You can still access LM via Ethernet / local IP. But Ethernet gateway won't be used. |
