recovery img Spacelink HW V3.2? - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Hardware (https://forum.logicmachine.net/forumdisplay.php?fid=12) +--- Thread: recovery img Spacelink HW V3.2? (/showthread.php?tid=4851) |
recovery img Spacelink HW V3.2? - edyzee11 - 29.06.2023 Can you share the recovery image of the spacelink lss100200. I have a spacelink with both green LEDs blinking and the internal red LED blinking at the same. RE: recovery img Spacelink HW V3.2? - Erwin van der Zwart - 29.06.2023 Here you go, don't forgot to extract before usage RE: recovery img Spacelink HW V3.2? - edyzee11 - 29.06.2023 Thank you very much, it works correctly. RE: recovery img Spacelink HW V3.2? - edyzee11 - 16.01.2024 For HW: V3.1 Can I recover the same image? RE: recovery img Spacelink HW V3.2? - Erwin van der Zwart - 16.01.2024 Yes when having a HW 2 or 3 it should work (imx6) RE: recovery img Spacelink HW V3.2? - tom@smart-consult.no - 06.02.2024 (16.01.2024, 21:34)Erwin van der Zwart Wrote: Yes when having a HW 2 or 3 it should work (imx6) Hi Erwin Can I use same recovery in SpaceLynk and Wiser ? I need to recover several Wiser RE: recovery img Spacelink HW V3.2? - Daniel - 06.02.2024 Use our recovery works on every hardware. Just make sure select correct CPU version. https://kb.logicmachine.net/misc/reflash-lm-and-streaming-player/ RE: recovery img Spacelink HW V3.2? - tom@smart-consult.no - 06.02.2024 (06.02.2024, 16:01)Daniel Wrote: Use our recovery works on every hardware. Just make sure select correct CPU version. Thank you Now they all run again |
