SDI-12 communication - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: SDI-12 communication (/showthread.php?tid=4857) |
SDI-12 communication - Joep - 03.07.2023 Hi All, Does anyone know if it's possible to integrate a weather station using SDI-12 communication? Also interested if you see any pros or cons. SDI-12 communication configuration Baud Rate 1200 Start Bits 1 Data Bits 7 (LSB first) Parity Bits 1 (even) Stop Bits 1 Logic Inverted (active low) Integration guide: http://publications.metergroup.com/Integrator%20Guide/18171%20ATMOS%2041%20Integrator%20Guide.pdf RE: SDI-12 communication - admin - 03.07.2023 You will need an extra protocol converter hardware, it cannot be connected directly. RE: SDI-12 communication - Joep - 03.07.2023 (03.07.2023, 14:19)admin Wrote: You will need an extra protocol converter hardware, it cannot be connected directly. Ok thanks admin. |
