MODBUS - Can't write on registers - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: MODBUS - Can't write on registers (/showthread.php?tid=4858) |
MODBUS - Can't write on registers - gdimaria - 03.07.2023 Hi, I created the attached modbus profiles for a fancoil. I CAN READ but I CAN'T WRITE on the holding registers (from 26301 to 26327). What is wrong? Thanks Peppe RE: MODBUS - Can't write on registers - admin - 04.07.2023 Incorrect spelling: not writeble but writable RE: MODBUS - Can't write on registers - gdimaria - 04.07.2023 Ooops.... that's embarassing! ![]() i did the fix, but i still can't write to the logs. Yet with a modbus tool software I can write in the registers, but in the 0x10 mode: write multiple registers, as reported in the pdf manual. RE: MODBUS - Can't write on registers - admin - 04.07.2023 See this: https://forum.logicmachine.net/showthread.php?tid=4814&highlight=write_multiple RE: MODBUS - Can't write on registers - gdimaria - 04.07.2023 The script in the post - I suppose should be put as init script - refers to a tcp modbus connection... I have an RTU. re And how I can map the registers to knx addresses? RE: MODBUS - Can't write on registers - Daniel - 04.07.2023 The suggestions is to use "write_multiple": 1 in your profile RE: MODBUS - Can't write on registers - gdimaria - 04.07.2023 (04.07.2023, 08:20)Daniel Wrote: The suggestions is to use "write_multiple": 1 in your profile OK Thanks! |
