https protocole on wiser - Printable Version
+--- Thread: https protocole on wiser (/showthread.php?tid=4867)
https protocole on wiser - mellotron - 11.07.2023
hi, how to setup https on wiser for knx
RE: https protocole on wiser - Daniel - 11.07.2023
If you use latest fw you will be forced to use https, the settings are in System - Services- HTTP server.
RE: https protocole on wiser - mellotron - 11.07.2023
(11.07.2023, 08:26)Daniel Wrote: If you use latest fw you will be forced to use https, the settings are in System - Services- HTTP server.
i have enable https but when i try load page on wiser my browser say my comunication is not secure
For browser to say it is secure you need SSL certificate, by default we are using self signed certificate for which browser will complain. On LM you can use SLL certificate app to generate proper certificate, for W4K you need to do it manually but this is very complex and painful process.
RE: https protocole on wiser - mellotron - 13.07.2023
(11.07.2023, 08:41)Daniel Wrote: For browser to say it is secure you need SSL certificate, by default we are using self signed certificate for which browser will complain.  On LM you can use SLL certificate app to generate proper certificate, for W4K you need to do it manually but this is very complex and painful process.
hi, thank for your answer please can you explain me the process
RE: https protocole on wiser - Daniel - 13.07.2023
https://deliciousbrains.com/ssl-certificate-authority-for-local-https-development/
This will work if you can upload it to all devices which will use it.
RE: https protocole on wiser - manos@dynamitec - 30.04.2024
(13.07.2023, 08:37)Daniel Wrote: https://deliciousbrains.com/ssl-certificate-authority-for-local-https-development/
Hello Daniel, Admin,
I am using two SpaceLynks where I need to upload the key and certificate gived by the end client but when pasting the text on the KEY field it gives error "invalid input". Certificate field doesn't give error.
Can I send PM you the Key a,d Certificate to check why this is not working?
FW on both SLs is 2.8.3.
Regards,
RE: https protocole on wiser - admin - 30.04.2024
Send it via PM.
(30.04.2024, 12:44)admin Wrote: Send it via PM.
Thank you Admin, for letting me know that we have to upload a decrypted private key.
