Push notifications - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Application Store (https://forum.logicmachine.net/forumdisplay.php?fid=11) +--- Thread: Push notifications (/showthread.php?tid=4883) |
Push notifications - gjniewenhuijse - 21.07.2023 Hello, In the past i used the app Push notifications to test sending push messages. But now it doesn't work anymore. When i hit the send button its grayed out and i see a moving circle (for long time). But nothing happen. I already: - checked the settings - deleted the app from my iphone and re-installed. Weird thing is that i see and old the following data in de push app (Apple iPhone13,3 iOS 14.7.1). But i have a newer phone and newer os. How to start solving this issue? How to register my new phone of check its right registered? RE: Push notifications - Daniel - 21.07.2023 Which iOS version do you have? RE: Push notifications - gjniewenhuijse - 21.07.2023 (21.07.2023, 13:36)Daniel Wrote: Which iOS version do you have? 16.5.1 © Iphone 12 Pro RE: Push notifications - Daniel - 21.07.2023 It worked for me on 16.5 will upgrade to latest RE: Push notifications - Daniel - 21.07.2023 Worked fine for me RE: Push notifications - gjniewenhuijse - 24.07.2023 (21.07.2023, 14:52)Daniel Wrote: Worked fine for me thats no solution ![]() can i re-add my phone or my lm to the cloud account, or can i debug the process to check where its gone wrong? RE: Push notifications - Daniel - 24.07.2023 As long we can't recreate the issue we can't solve it. Make sure that you are on the same local network as LM while adding it. If LM wasn't added to Push app, in mobile app disable push notifications, save edit again enable push notifications and save. Make sure to use latest push app and LM cloud. RE: Push notifications - CristianAgata - 24.07.2023 (24.07.2023, 05:48)gjniewenhuijse Wrote:Hi,(21.07.2023, 14:52)Daniel Wrote: Worked fine for me May I ask you if you have changed the name of the logic? I have this problem if I changed the name. Best regards Cristian RE: Push notifications - gjniewenhuijse - 24.07.2023 (24.07.2023, 09:26)CristianAgata Wrote:(24.07.2023, 05:48)gjniewenhuijse Wrote:Hi,(21.07.2023, 14:52)Daniel Wrote: Worked fine for me My name: LogicMachine RE: Push notifications - gjniewenhuijse - 25.07.2023 solved: removed and reinstalled the push notification app and it works again. RE: Push notifications - Cybernetics - 08.09.2025 Can someone please send me the Push Notification ipk? thank you in advance. RE: Push notifications - Daniel - 09.09.2025 Why would you want the Push notification ipk? The new solution with LM Home doesn't need it. https://kb.logicmachine.net/notifications/push-notifications/ RE: Push notifications - icuzz - 12.09.2025 It would be nice to have token free/send to all tokens push notification so that it sends it all the devices that are logged in to the server with the app. Personally I like the option of tokens because then you can customize push notifications to diffferent devices. |
