Zigbee sensor and thermostat - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Zigbee sensor and thermostat (/showthread.php?tid=4903) |
Zigbee sensor and thermostat - FrancescoBellino - 03.08.2023 Good morning. I have 2 devices that uses Zigbee as transmission protocol. The first one is a sensor from Schneider (SED-TRH-G-5045) which I can't pair with the Logic Machine. Do you know why? The only reason that i found is about the type of Zigbee used, that in this case is Zigbee green power. The second one is a thermosat that I paired succesfully. I uploaded in the attachment the log export and the data from the informations in the device tab of the app. Thank you in advance! RE: Zigbee sensor and thermostat - admin - 03.08.2023 Green power devices are not supported. TS0601 won't work due to not using standard ZigBee clusters: https://forum.logicmachine.net/showthread.php?tid=3320&pid=31021#pid31021 RE: Zigbee sensor and thermostat - FrancescoBellino - 03.08.2023 (03.08.2023, 09:49)admin Wrote: Green power devices are not supported. Thank you for the feedback. I will try to search another one. Do you know a thermostat with 230V power supply and a contact for the heat valve that is already integrated in the Zigbee app? I found this one on the forum but is too much complicated for my purpose... link: China ZigBee Fan Coil Thermostat (100V-240V) PCT504-Z factory and manufacturers | Owon Technology (owon-smart.com) Good morning RE: Zigbee sensor and thermostat - FrancescoBellino - 22.08.2023 (03.08.2023, 09:49)admin Wrote: Green power devices are not supported. Good Morning, I received the new thermostat which was suggested in the forum. These are the device informations: Manufacturer: OWON Technology Inc. Model: PCT504-E Device type: Router Power source: Mains Receive when idle: Yes Endpoint 1 Profile: 260 Input clusters - Basic (0) - Identify (3) - Groups (4) - Scenes (5) - HvacThermostat (513) - HvacFanCtrl (514) - HvacUserInterfaceCfg (516) - MsRelativeHumidity (1029) Output clusters - Time (10) Endpoint 2 Profile: 260 Input clusters - Basic (0) - Identify (3) - MsOccupancySensing (1030) It is integrable in the Logic Machine app? Thank you in advance! RE: Zigbee sensor and thermostat - fleeceable - 23.08.2023 These supported devices should be plug and play: https://openrb.com/docs/zigbee-devices.htm RE: Zigbee sensor and thermostat - FrancescoBellino - 24.08.2023 (23.08.2023, 06:53)fleeceable Wrote: These supported devices should be plug and play: Good morning. Unfortunately, I cannot find a thermostat for my project in that list. This is why I searched in the forum as admin suggested and I found the thermostat that I sent last day. In this project we have a lot of constraints... Thank you anyway for the reply! RE: Zigbee sensor and thermostat - admin - 24.08.2023 Preliminary profile for this device will be added in the next app version. It's not guaranteed that all features will be implemented and will work as we don't have the actual device to test them. RE: Zigbee sensor and thermostat - DGrandes - 06.02.2024 Hi!! I have the same valve "TS0601". I´ve seen that in a bridge Github have integrated this valve. https://www.zigbee2mqtt.io/devices/TS0601_thermostat.html Is there any way to set/get comands from script with this valve? In this page you can see available features. I can´t see HVAC commands in zigbee library: https://kb.logicmachine.net/libraries/zigbee/ I´ve seen some HVAC devices in zigbee compatibilites as Wiser thermostat: https://kb.logicmachine.net/misc/zigbee-devices/ Thanks!! RE: Zigbee sensor and thermostat - admin - 06.02.2024 This has already been asked several times. TS0601 won't work due to not using standard ZigBee HVAC clusters: https://forum.logicmachine.net/showthread.php?tid=3320&pid=31021#pid31021 |
