Mbus - Printable Version
+--- Thread: Mbus (/showthread.php?tid=4927)
Mbus - Christopher - 18.08.2023
Hi.
I'm trying to poll some carlo gawazzi meters an have tried everything (i think) but are nok able to get a respone from them.
I'm using this script and have tried to change the baud rate and duplex.
I have tried to scan for 254 elements,
require('mbus') mbus.init('/dev/RS232', 2400) res, err = mbus.scan( 0, 10, 5) log(res) log(err)
I have also tried to check my connections on the Rx/Tx both on LM5 and the meters.
But still I only got these responses:
m-bus 18.08.2023 12:45:44 * table: m-bus 18.08.2023 12:45:44 * nil
HW: LM5 Lite + Ext (i.MX6)
SW: 20230607
I there something I'm missing out?
RE: Mbus - admin - 18.08.2023
You need an external Mbus to RS232 or RS485 converter.
RE: Mbus - Rune - 16.10.2023
"You need an external Mbus to RS232 or RS485 converter. "
Do you got any examples of a converter like this?
RE: Mbus - admin - 16.10.2023
We've used these converters: http://www.techbase.eu/en/products/mbus-converters.html
RE: Mbus - Domoticatorino - 23.04.2024
Hi Admin,
I take this opportunity to ask you about the integration of M-BUS Engelmann heater meter using Techbase interface.
Is enough simply to know that the meter is M-bus or shall it has some technical features?
RE: Mbus - admin - 23.04.2024
Check this guide: https://kb.logicmachine.net/integration/mbus/
(23.04.2024, 07:48)admin Wrote: Check this guide: https://kb.logicmachine.net/integration/mbus/
I have already read it. So the only important data is knowing the baud rate of the meter and the type of communication (rs232 or 485).
