sciprt LUA Wiser - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: sciprt LUA Wiser (/showthread.php?tid=4929) |
sciprt LUA Wiser - emmanuel.dassi - 20.08.2023 Hello i have a wiser for KNX in my systeme, and i wrote a script in witch the wiser must create a directory and create a CSV file there. i would like to be sure that my script works well. how to open this file? or how to download it? how to see the dierctory i created? RE: sciprt LUA Wiser - Erwin van der Zwart - 20.08.2023 Can you share the content of your script? RE: sciprt LUA Wiser - admin - 21.08.2023 Most likely script writes to the FTP path. You can access these files using an FTP client. First you need to enable FTP server in System config > Services > FTP server. Use ftp login not apps. |
