Mosaic2.0 still using it? - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Application Store (https://forum.logicmachine.net/forumdisplay.php?fid=11) +--- Thread: Mosaic2.0 still using it? (/showthread.php?tid=4930) |
Mosaic2.0 still using it? - f4229914093 - 21.08.2023 hi admin My Mosaic2.0 cannot be opened. with LM2IF3F. The current version is 20170620, and trying to upgrade lm2i-20230607 has no effect. Installing Mosaic3.0 prompts me with 'Error in/www/apps/data/mosaic30/lua/tpl_head.lp at line 298: unexpected symbol near'='. Is there any solution? RE: Mosaic2.0 still using it? - admin - 21.08.2023 What is the exact hardware model? Open the enclosure. If you see a CPU module with a uSD card slot then it can upgraded by replacing the card and following the recovery procedure. If you have hardware with built-in flash then nothing can be done with it - this device is no longer supported, you need to buy new LM. |
