Invalid CRC after lightning transient. - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Invalid CRC after lightning transient. (/showthread.php?tid=4939) |
Invalid CRC after lightning transient. - ClausP - 31.08.2023 Hello everyone. After a lager thunderstorm, i have had a transient damaging the indput on my router, where the W4K is installed. Afterward I have found an error on my modbus signal saying Invalid CRC when I connect my ventilation system (Nilan 305). I also get an error on reading my energymeter saying "Read fail: Operation timed out" , but the data is still updated in the group object? Any surgestions on solving this problem?
RE: Invalid CRC after lightning transient. - admin - 01.09.2023 Might be a damaged RS-485 transceiver on of the devices. Communication errors can appear from time to time if the signal stability is on the edge. The usual recommendation is to connect GND between all devices, use bus wiring topology and connect a termination resistor if the bus is long. RE: Invalid CRC after lightning transient. - ClausP - 04.09.2023 (01.09.2023, 10:02)admin Wrote: Might be a damaged RS-485 transceiver on of the devices. Okay The bus lenght is about 4 meters, so should'n be a problem. I've used daisy chain topology. I thing maybee I will just get the insurance to repair it, and the mount a modbus transient protection unit
