Neighbour Timeout issue - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Neighbour Timeout issue (/showthread.php?tid=4957) |
Neighbour Timeout issue - john - 11.09.2023 Hi All, I am having a issue using the neighbour import function. I have 21.000 objects roughly which I am trying to import from one LM to another. They are on the same network. The message I am getting is "Error: Timeout". All the objects have datatypes and the Remote Services are enabled (and passwords match). Anyone have any fixes to this? RE: Neighbour Timeout issue - Daniel - 11.09.2023 Your LM probably runs out of memory as this object amount is just crazy high. RE: Neighbour Timeout issue - john - 11.09.2023 (11.09.2023, 12:33)Daniel Wrote: Your LM probably runs out of memory as this object amount is just crazy high. Hi Daniel, The memory is showing up as 28%. I am using this LM as a master unit with all the objects. I have multiple sub LM as area couplers which run all the processes and logic. The master is just for remote monitoring from a single source. Is there a limitation of objects we can have? It doesn't seem to be a memory issue from what I can see. RE: Neighbour Timeout issue - Daniel - 11.09.2023 The biggest project I ever saw was 8k objects and it barely worked. |
