LogicMachine5 Reactor IO v2 EnOcean problem! - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: LogicMachine5 Reactor IO v2 EnOcean problem! (/showthread.php?tid=4959) |
LogicMachine5 Reactor IO v2 EnOcean problem! - Novodk - 11.09.2023 I have a brand new Reactor IO v2 but the EnOcean is not working, how do I test it? I have a button that works with my Wiser, but on the Reactor im not getting anything in Interfaces! RE: LogicMachine5 Reactor IO v2 EnOcean problem! - admin - 12.09.2023 Do you have on-board EnOcean interface or USB? RE: LogicMachine5 Reactor IO v2 EnOcean problem! - Novodk - 12.09.2023 On-board it's a LM5p2RIO2E - LogicMachine5 Reactor IO V2 EnOcean Power RE: LogicMachine5 Reactor IO v2 EnOcean problem! - Daniel - 12.09.2023 Power down the controller and open the top cover with a screwdriver. It is possible that the enocean board did disconnect. It will be the one closest to the top. RE: LogicMachine5 Reactor IO v2 EnOcean problem! - Novodk - 12.09.2023 (12.09.2023, 08:30)Daniel Wrote: Power down the controller and open the top cover with a screwdriver. It is possible that the enocean board did disconnect. It will be the one closest to the top. ![]() I took the white plastic cover off and put the board into the connector, assembled everything and powered it on, still nothing in EnOcean > Interfaces RE: LogicMachine5 Reactor IO v2 EnOcean problem! - edgars - 12.09.2023 Hi! Please contact us via email to agree on replacement / fixing. RE: LogicMachine5 Reactor IO v2 EnOcean problem! - DGrandes - 25.11.2023 Hello! I have some ABB Enocean valves that are working with a KNX-Enocean gateway. Now I have a Reactor with the Enocean antenna and I am trying to link one of them but I am not able to. Does the Logic Machine have a button to start pairing? Thanks RE: LogicMachine5 Reactor IO v2 EnOcean problem! - admin - 27.11.2023 See this: https://forum.logicmachine.net/showthread.php?tid=753 And check the valve manual page 19 (Commissioning). RE: LogicMachine5 Reactor IO v2 EnOcean problem! - DGrandes - 12.12.2023 (27.11.2023, 08:34)admin Wrote: See this: https://forum.logicmachine.net/showthread.php?tid=753 Hi, I dont´understand the proccess to receive information from enocean valves. Set the incomming A5-20-04 data telegram (default marked as unsupported) to a 4 byte RAW profile and link it to a new 4 byte unsigned integer object. (not splitted!) I dont´know how to receive the incomming A5-20-04 data telegram. ¿What is the meaning of 4 byte RAW profile in Logic Machine? I can´t see anything in enocan tab and I can´t link valves. ¿How can activate learning mode in Logic Machine? Thanks RE: LogicMachine5 Reactor IO v2 EnOcean problem! - admin - 12.12.2023 Which hardware model do you have? There should be an adapter detected in the EnOcean tab, otherwise it won't work. You don't need to put LM into learning mode, it will catch all incoming telegrams automatically. When the valve is detected then the profile in valve settings must be changed to 4 byte RAW. RE: LogicMachine5 Reactor IO v2 EnOcean problem! - DGrandes - 13.12.2023 This is the hardware. A Reaktor with enocean anthena (No usb). When I put valve in learning mode, nothing appears in "Actuators" enocean tab in Logic Machine. This is the valbe: RE: LogicMachine5 Reactor IO v2 EnOcean problem! - Daniel - 13.12.2023 Do you have any other enocean device to test? Open the top cover to see if you have the same issue as above. RE: LogicMachine5 Reactor IO v2 EnOcean problem! - DGrandes - 13.12.2023 (13.12.2023, 08:17)Daniel Wrote: Do you have any other enocean device to test? I have 7 valves. And I try it with 3. Here the Logic Machine RE: LogicMachine5 Reactor IO v2 EnOcean problem! - Daniel - 13.12.2023 This board on a left is enocean extension and it is disconnected. Please try connecting it back it has pins below. It it wont work after connecting contact us via email for replacement. RE: LogicMachine5 Reactor IO v2 EnOcean problem! - DGrandes - 13.12.2023 (13.12.2023, 13:22)Daniel Wrote: This board on a left is enocean extension and it is disconnected. Please try connecting it back it has pins below. It it wont work after connecting contact us via email for replacement. It works! i can see valves. I didn´t see that extension was disconected. Thanks! I´ll try scripts Thanks |
