Modbus ASCII - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Modbus ASCII (/showthread.php?tid=4976) |
Modbus ASCII - FatMax - 20.09.2023 I have a device connected through Modbus TCP/IP where one of the registers contains FW-version of client. However, datatype is ASCII. Is it possible to poll this with a profile? RE: Modbus ASCII - Daniel - 20.09.2023 No but you can try reading it via script, use modbus proxy alongside profile. RE: Modbus ASCII - admin - 20.09.2023 String datatype support has been recently added to profiles. Apart from "datatype": "string" you also need to specify the number of registers to read - "read_count": 6 Null (zero) bytes are automatically removed from the final string value. RE: Modbus ASCII - FatMax - 20.09.2023 What would be considered newer FW for the SL? I'm on 2.7.0. Edit: Tried to create a profile but the SL responded with invalid field for datatype when it was string. Tried this: https://forum.logicmachine.net/showthread.php?tid=1245&pid=7434#pid7434 But just getting an empty string as the result. RE: Modbus ASCII - admin - 20.09.2023 2.7.0 is not the latest firmware. Try reading these registers via read test, it's quite possible that the version is all zeros. RE: Modbus ASCII - FatMax - 20.09.2023 The script actually worked fine, but as always I had to subtract 1 from the modbusregister for it to work. Thank you! |
