JSON post request being weird - Printable Version
+--- Thread: JSON post request being weird (/showthread.php?tid=4979)
JSON post request being weird - Seijboldt - 20.09.2023
I've garbled a script I found, but for some reason my API is refusing the JSON content.
Maybe I've got a typo or I'm just slow..
Here is my current code:
require('socket.http') require('json') require("ltn12") body = '{"fault": true,"instID": "string","value": 0,"name": "string"}' response = {} start = grp.getvalue('12/4/0') socket.http.request({       url = "http://192.168.1.69/docs",    method = 'POST',      sink = ltn12.sink.table(response),   headers = {         ['accept'] = 'application/json',      ['content-type'] = 'application/json',             },       source = ltn12.source.string(body),         }) log(response,headers)
That results in this:
string: {"detail":[{"type":"missing","loc":["body"],"msg":"Field required","input":null}]}
Which I could probably live with as it's just missing some or all values in the JSON format, but I decided to try it through CURL and that works and returns 201 success:
curl -X 'POST' \   'http://192.168.1.69/docs' \   -H 'accept: application/json' \   -H 'Content-Type: application/json' \   -d '{"fault": true,"instID": "string","value": 0,"name": "string"}'
I've tried enclosing "true" and "0" in " but that doesn't make a difference.
Any ideas would be greatly appreciated.
RE: JSON post request being weird - admin - 21.09.2023
You are missing the content-length header. It is also advisable to use json.encode to create JSON strings instead of manual creation which can lead to errors.
RE: JSON post request being weird - Seijboldt - 21.09.2023
(21.09.2023, 05:06)admin Wrote: You are missing the content-length header. It is also advisable to use json.encode to create JSON strings instead of manual creation which can lead to errors.
I've added the header, with it in I get a internal server error Sad
This should be correct, right?
mac = io.readfile('/sys/class/net/eth0/address'):trim() require('socket.http') require('json') require("ltn12") jsoncontent = json.encode({fault = true,instID= "teststring",value= 22,name = "stringname"}) body = jsoncontent response = {} log("test") socket.http.request({       url = "http://192.168.1.69/docs",    method = 'POST',      sink = ltn12.sink.table(response),   headers = {      ["Content-Length"] = string.len(body),         ['accept'] = 'application/json',      ['content-type'] = 'application/json',             },       source = ltn12.source.string(body),         }) log(response,body)
Check error logs on your server. This request works correctly when testing with https://httpbin.org/post
RE: JSON post request being weird - Seijboldt - 22.09.2023
(21.09.2023, 08:28)admin Wrote: Check error logs on your server. This request works correctly when testing with https://httpbin.org/post
You are correct, had a imported library on my server that made some issues.
