Zerotier - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Zerotier (/showthread.php?tid=4985) |
Zerotier - rw_echo - 25.09.2023 The old LM firmware is missing the zerotier.ikp file. Does anyone have its installation package? Can you share it? Thank you! RE: Zerotier - admin - 25.09.2023 ZeroTier is built into firmware, so simply update yours and it will appear. This only applies to devices with newer CPU (i.MX6). Older hardware does not support ZeroTier. RE: Zerotier - rw_echo - 25.09.2023 The latest hardware login requires changing the administrator password, which I don't want to do. It would be even better if I could install it through the "zero tier. ipk" interface in System>packcaes RE: Zerotier - Zen - 27.09.2023 (25.09.2023, 08:47)rw_echo Wrote: The latest hardware login requires changing the administrator password, which I don't want to do. It would be even better if I could install it through the "zero tier. ipk" interface in System>packcaes Try to restore another firmware but not the later 2022 nor 2023 cause they force psw update. Try fw. 20210521, this for sure not require password changes. |
