Trends to csv - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Trends to csv (/showthread.php?tid=5006) |
Trends to csv - jobb@nordstrandsel.se - 06.10.2023 Hello, I want to create a csv file for the last 30 days. I have a script as below, but it creates not that many days. What has to be changed? /Fredrik Code: require('trends')
dates = {}
dates['start'] = os.date('*t')
dates['start'].day = dates['start'].day - 1
dates['end'] = os.date('*t')
now = os.time()
function fetch(tname)
local res = {}
local values = trends.fetch(tname, dates)
local count = #values
local step = 86400 / count
for i, value in ipairs(values) do
table.insert(res, {
now - (count - i) * step,
value
return res
buf = {
fetch('LUFTTEMPERATUR W'),
fetch('NEDERBÖRDSMÄNGD W'),
fetch('VINDRIKTNING W'),
fetch('NEDERBÖRD INTENSITET W'),
fetch('GENOMSNITTLIG VINDHASTIGHET W'),
fetch('RELATIV LUFTFUKTIGHET W'),
fetch('MAX VINDHASTIGHET W'),
fetch('ABSOLUT LUFTTRYCK W')
csv = { 'Id,Site Id,Site Authentication Key,Report Date / Time,Temperature,Precipitation accumulated,Wind direction,Precipitation intensity,Average wind, Humidity,Downwind,Air pressure at station' }
for i, row1 in ipairs(buf[ 1 ]) do
date = os.date('%d/%m/%y %H:%M', row1[ 1 ])
value1 = row1[ 2 ]
row2 = buf[ 2 ][ i ] or {}
value2 = row2[ 2 ] or 0
row3 = buf[ 3 ][ i ] or {}
value3 = row3[ 2 ] or 0
row4 = buf[ 4 ][ i ] or {}
value4 = row4[ 2 ] or 0
row5 = buf[ 5 ][ i ] or {}
value5 = row5[ 2 ] or 0
row6 = buf[ 6 ][ i ] or {}
value6 = row6[ 2 ] or 0
row7 = buf[ 7 ][ i ] or {}
value7 = row7[ 2 ] or 0
row8 = buf[ 8 ][ i ] or {}
value8 = row8[ 2 ] or 0
csv[ #csv + 1 ] = string.format(' fb6ca12c-3106-ee11-913a-201642ba599e,20230608tey3apeggae67rj4rymrfqtn3c,Grimeljer2023!,%s,%.2f,%.2f,%.2f,%.2f,%.2f,%.2f,%.2f,%.2f',
date, value1, value2, value3, value4, value5, value6, value7, value8)
csv = table.concat(csv, '\n')
log(csv)
to = 'email@email.com'
settings = {
from = ' email@email.com ',
-- smtp username
user = ' email@email.com ',
-- smtp password
password = 'Password',
-- smtp server
server = 'smtp.gmail.com',
-- smtp server port
port = 465,
-- enable ssl, required for gmail smtp
secure = 'sslv23',
subject = 'CSV väder'
smtp = require('socket.smtp')
mime = require('mime')
ltn12 = require('ltn12')
function escape(v)
return '<' .. tostring(v) .. '>'
to = escape(to)
msgt = {
headers = {
to = to,
['content-type'] = 'text/csv',
['content-disposition'] = 'attachment; filename="logs.csv"',
['content-transfer-encoding'] = 'BASE64',
subject = subject,
body = ltn12.source.chain(
ltn12.source.string(csv),
ltn12.filter.chain(mime.encode('base64'), mime.wrap('base64'))
settings.source = smtp.message(msgt)
settings.from = escape(settings.from)
settings.rcpt = { to }
res, err = smtp.send(settings)
log(res, err)RE: Trends to csv - admin - 06.10.2023 Replace: Code: dates['start'].day = dates['start'].day - 1With: Code: dates['start'].day = dates['start'].day - 30RE: Trends to csv - jobb@nordstrandsel.se - 06.10.2023 (06.10.2023, 08:48)admin Wrote: Replace: Thank you! But it seems to be only the last 24 hours in the csv file. What can be wrong? /Fredrik RE: Trends to csv - admin - 06.10.2023 Line 14 should be: Code: local step = 30 * 86400 / countRE: Trends to csv - jobb@nordstrandsel.se - 06.10.2023 Thank you! It seems to work, but the time and date does not match. if i look at csv from script, date, time and values come like this. " 23/10/06 14:30" 1010.56 " 23/10/06 14:45" 1011.20 " 23/10/06 15:00" 1011.20 " 23/10/06 15:15" 1011.20 " 23/10/06 15:30" 1011.20 " 23/10/06 15:45" 1011.20 " 23/10/06 16:00" 1011.20 " 23/10/06 16:15" 1011.20 " 23/10/06 16:30" 1011.20 " 23/10/06 16:45" 1011.20 " 23/10/06 17:00" 1011.20 " 23/10/06 17:15" 1011.20 And if i download a csv file from the day before 23/10/05 it shows this. 21:15,"1010.56" 21:30,"1011.2" 21:45,"1011.2" 22:00,"1011.2" 22:15,"1011.2" 22:30,"1011.2" 22:45,"1011.2" 23:00,"1011.2" 23:15,"1011.2" 23:30,"1011.2" 23:45,"1011.2" 24:00,"1011.2" It means that the last value i was testing to send from script, is the last value from the day before. How can i correct this? /Fredrik RE: Trends to csv - admin - 09.10.2023 Try replacing fetch function with this: Code: function fetch(tname)
return trends.fetch(tname, dates, nil, true)
endRE: Trends to csv - jobb@nordstrandsel.se - 09.10.2023 Thank you! Now it's 1h 45m difference. if i look at csv from script, date, time and values come like this. 2023-10-08 22:45,7.90,0.00,291.20,0.00,2.40,52.00,2.80,1013.76" 2023-10-08 23:00,7.70,0.00,269.60,0.00,1.80,52.60,1.80,1013.12" 2023-10-08 23:15,7.50,0.00,287.36,0.00,2.30,52.88,2.40,1013.12" 2023-10-08 23:30,7.30,0.00,272.80,0.00,1.80,53.68,1.90,1013.12" 2023-10-08 23:45,7.20,0.00,302.72,0.00,1.10,55.00,1.10,1013.12" 2023-10-09 00:00,7.10,0.00,275.68,0.00,0.90,55.20,1.10,1013.12" 2023-10-09 00:15,7.00,0.00,299.20,0.00,1.40,55.00,2.50,1013.12" 2023-10-09 00:30,6.80,0.00,298.72,0.00,3.40,55.60,3.80,1013.12" 2023-10-09 00:45,6.60,0.00,291.36,0.00,3.40,56.28,3.60,1013.12" 2023-10-09 01:00,6.50,0.00,256.16,0.00,0.80,57.08,0.80,1013.12" 2023-10-09 01:15,6.40,0.00,296.64,0.00,1.40,58.80,1.50,1013.12" 2023-10-09 01:30,6.10,0.00,276.80,0.00,1.50,59.40,2.00,1013.12" 2023-10-09 01:45,6.00,0.00,350.40,0.00,0.50,59.68,0.60,1012.48" And if i download a csv file from the day before 23/10/08 it shows this. 21:00,"1013.76" 21:15,"1013.12" 21:30,"1013.12" 21:45,"1013.12" 22:00,"1013.12" 22:15,"1013.12" 22:30,"1013.12" 22:45,"1013.12" 23:00,"1013.12" 23:15,"1013.12" 23:30,"1013.12" 23:45,"1013.12" 24:00,"1012.48" How can i correct this? /Fredrik RE: Trends to csv - admin - 09.10.2023 Timestamps are in UTC which conversion to date string does not take into account. Replace this: Code: date = os.date('%d/%m/%y %H:%M', row1[ 1 ])With this: Code: date = os.date('!%d/%m/%y %H:%M', row1[ 1 ])There's bug in CSV export in Trends UI where data is shifted by one step (15 minutes in your case). RE: Trends to csv - jobb@nordstrandsel.se - 10.10.2023 Ok, thank you! Now the result is this. It's 15 min difference... Best! /Fredrik 2023-10-09 20:45,7.70,0.00,251.84,0.00,1.00,63.00,1.10,1009.92" 2023-10-09 21:00,7.80,0.00,276.80,0.00,1.20,63.20,1.40,1009.28" 2023-10-09 21:15,7.50,0.00,268.16,0.00,1.30,65.00,1.50,1009.92" 2023-10-09 21:30,7.10,0.00,255.36,0.00,1.30,67.40,1.30,1009.92" 2023-10-09 21:45,7.10,0.00,240.48,0.00,0.50,67.40,0.60,1009.92" 2023-10-09 22:00,6.90,0.00,260.00,0.00,1.20,67.80,1.20,1009.92" 2023-10-09 22:15,6.60,0.00,263.04,0.00,0.60,71.60,0.80,1009.92" 2023-10-09 22:30,6.60,0.00,243.36,0.00,1.00,75.40,1.00,1009.92" 2023-10-09 22:45,6.60,0.00,239.52,0.00,1.20,76.40,1.40,1009.92" 2023-10-09 23:00,6.50,0.00,258.08,0.00,0.90,76.40,0.90,1009.92" 2023-10-09 23:15,6.30,0.00,197.12,0.00,0.60,76.60,0.60,1009.92" 2023-10-09 23:30,6.10,0.00,216.00,0.00,0.50,75.68,0.70,1009.92" 2023-10-09 23:45,5.90,0.00,199.68,0.00,1.70,75.20,2.10,1009.92" 20:45,"1009.28" 21:00,"1009.92" 21:15,"1009.28" 21:30,"1009.92" 21:45,"1009.92" 22:00,"1009.92" 22:15,"1009.92" 22:30,"1009.92" 22:45,"1009.92" 23:00,"1009.92" 23:15,"1009.92" 23:30,"1009.92" 23:45,"1009.92" 24:00,"1009.92" RE: Trends to csv - admin - 10.10.2023 I've already mentioned this: There's bug in CSV export in Trends UI where data is shifted by one step (15 minutes in your case). Switch to Data when viewing trends, you will get the same 15 minutes difference with exported data. |
