Z WAVE - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Z WAVE (/showthread.php?tid=501) |
Z WAVE - hima - 09.12.2016 Hello, When the server LM4 was powered OFF and ON ( or else rebooted ), upon z wave configuration page, all the devices are shown as active. But actually none of them works. We need to press the program button of each ( even powered z wave device ) device to wake them up. After this action, it starts working. It is really a pain because some devices are installed at double height locations and every-time waking them is not so reliable. Please give us your suggestion ! RE: Z WAVE - edgars - 09.12.2016 Hello Hima, please read this forum thread about wakeup interval: http://forum.logicmachine.net/showthread.php?tid=476&pid=2719#pid2719 RE: Z WAVE - hima - 12.12.2016 We are not able to change this on relay parameter. It goes back to the default value ! Also everytime we need to wake those devices up when there is a power failure. Its tough to open the switch box all the time. RE: Z WAVE - edgars - 13.12.2016 We have tested with Fibaro motion sensor, it is sensor's setting. The controller/LM cannot wake up the device while it doesn't come online itself. Please let me know what kind of Zwave devices are you using? You are welcome to send me log file to email. You can grab it here: http://IP_LogicMachine/apps/data/zwaveapp/__log.lp RE: Z WAVE - hima - 14.12.2016 (13.12.2016, 10:30)edgars Wrote: We have tested with Fibaro motion sensor, it is sensor's setting. The controller/LM cannot wake up the device while it doesn't come online itself. The issue is with the powered relays and dimmers and not the battery operated devices. We are using Fibaro relay FGS 211, Fibaro dimmer FGD 211, Fibaro door senor and fibaro universal input interface. We can't setup the polling time on powered devices ! RE: Z WAVE - hima - 15.12.2016 Also one more issue we are facing. The z wave USB is not initializing. Deamon tool is started but no setup for the USB z wave in list of devices.
RE: Z WAVE - gaxy - 01.01.2017 Hi I have a PH-PAT02-B.eu Multisensor 2in1, it works more or less ok but i am not able to save the advanced settings, it allway shows me the default settings, i can change them but after the save butten the settings are shown as before. also i am not able to use the polling checkbox on the basic settings page. kind regards RE: Z WAVE - gaxy - 05.01.2017 any news on that? |
