zigbee firmware update error - Printable Version
+--- Thread: zigbee firmware update error (/showthread.php?tid=5029)
zigbee firmware update error - domotiqa - 16.10.2023
Hello, did you experience this pb with the LSS100400 ?
.txt   logs.txt (Size: 20.93 KB / Downloads: 3)
RE: zigbee firmware update error - Daniel - 16.10.2023
You probably have old generation sample, if this is the case bin it.
RE: zigbee firmware update error - domotiqa - 16.10.2023
(16.10.2023, 07:52)Daniel Wrote: You probably have old generation sample, if this is the case bin it.
it s SE commercial who gave to me for testing before deploying (as filed test).
Yes but there were two versions old and new, old should be binned as it has old fw with no ability to upgrade. Ask SE, if you part of the pilot then they would provide you with all the info.
(16.10.2023, 08:23)Daniel Wrote: Yes but there were two versions old and new, old should be binned as it has old fw with no ability to upgrade. Ask SE, if you part of the pilot then they would provide you with all the info.
ok thks, I asked the Team but I had no answer yet.
I will go futher with them.
Thks Daniel
