Help with the use of storage.set and storage.get - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Help with the use of storage.set and storage.get (/showthread.php?tid=5039) |
Help with the use of storage.set and storage.get - legolas2069 - 18.10.2023 Hello, I'm testing the use of storage function to first understand it, and then visualize some data with JS functions. First, I write some data in a variable and I storage it: Code: data = {1,2,3,4,5,6,7,8}
storage.set('/user/example.lp', data)Second, I read this data and I log it for viewing the result: Code: store = storage.get('/user/example.lp', {})
log(store)After that, I try to view it on a browser console, for which I use custom JavaScript (the first console.log it's to see that is working): Code: $(function(){
console.log('Hello');
$.get('/user/example.lp', function(exampleData) {
console.log(exampleData);
});But I received a 404 code for the GET, and it says: Not found. What am I doing wrong? I've also tried to explore the user folder with Filezilla, but it's empty. Thank you for your help. RE: Help with the use of storage.set and storage.get - admin - 18.10.2023 Use FTP to upload .lp files. Storage is like a database, it does not store data in separate files in the filesystem. RE: Help with the use of storage.set and storage.get - legolas2069 - 18.10.2023 (18.10.2023, 10:09)admin Wrote: Use FTP to upload .lp files. Storage is like a database, it does not store data in separate files in the filesystem. Understood. How can I do it? I figure this, but I'm not sure It's ok Write to FTP: Code: data_ftp = {8,7,6,5,4,3,2,1}
io.writefile('example.lp', data_ftp)Read from FTP: Code: data_ftp, err = io.readfile('example.lp')
log(data_ftp, err)Custom javaScript: Code: $(function(){
$.get('example.lp', function(exampleData) {
});And the same error code 404, not found. In Filezilla I don't find it. I tried to look for it in the forum using search, but I didn't find it. Thank you. RE: Help with the use of storage.set and storage.get - admin - 18.10.2023 You need to use absolute paths. In Lua code use /www/user/example.lp instead of example.lp. In JavaScript code use /user/example.lp instead of example.lp RE: Help with the use of storage.set and storage.get - legolas2069 - 18.10.2023 Done and it works, thank you! |
