Wrong password - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Wrong password (/showthread.php?tid=5042) |
Wrong password - a455115 - 19.10.2023 Hello everyone, I am interested in setting up email notifications for incorrect password entries. I would also like to limit the number of password entry attempts to enhance security. I have tried exploring the documentation and event-based scripting feature, but I haven't found a clear solution yet. Is there a built-in feature or script to set up email notifications whenever an incorrect password is entered? How can I limit the number of incorrect password entry attempts? If there isn’t a built-in feature, could someone guide me on how to create a custom script for these functionalities? Any help or guidance would be greatly appreciated. Thank you in advance! Best regards, RE: Wrong password - Daniel - 19.10.2023 LM has a build in brute force protection, it will block a user after 5 wrong attempts for a minute. You can see logs in user access logs. You can modify this example for your need. https://forum.logicmachine.net/showthread.php?tid=4028&pid=26027#pid26027 RE: Wrong password - a455115 - 19.10.2023 (19.10.2023, 09:47)Daniel Wrote: LM has a build in brute force protection, it will block a user after 5 wrong attempts for a minute. You can see logs in user access logs. You can modify this example for your need. I'm having trouble understanding how to capture a "failed attempt" to log into the system. Could you provide an example of how to log such an attempt? RE: Wrong password - Daniel - 19.10.2023 Check this Code: items = db:getall([[
SELECT user_logs.*, users.name
FROM user_logs
JOIN users ON user_logs.login=users.login
ORDER BY user_logs.id DESC
LIMIT 50
for _, item in ipairs(items) do
cls = toboolean(item.failed) and 'danger' or 'success'
log(item.login,item.name, cls, item.ip)
end RE: Wrong password - a455115 - 19.10.2023 (19.10.2023, 11:06)Daniel Wrote: Check this This was the code I tried according to the example, but it doesn't work. RE: Wrong password - Daniel - 19.10.2023 What doesn't work? It works for me. RE: Wrong password - a455115 - 19.10.2023 (19.10.2023, 11:31)Daniel Wrote: What doesn't work? It works for me. Log is empty, nothing is recorded. Is there anything else to do besides the code? RE: Wrong password - Daniel - 19.10.2023 Do you have anything in Access logs? RE: Wrong password - a455115 - 19.10.2023 Yes, Access log is ok, but log is empty. I tested in http://4n.lv:7999/apps/, results is same. Log is empty. RE: Wrong password - Daniel - 19.10.2023 This is a special LM where many features are blocked for security, it works on my local LM. RE: Wrong password - Daniel - 19.10.2023 which fw do you have? Any errors? RE: Wrong password - a455115 - 19.10.2023 (19.10.2023, 11:46)Daniel Wrote: which fw do you have? Any errors? latest firmware version. There are no errors. I will try again later and write, but I think it is not entering the cycle. RE: Wrong password - Daniel - 19.10.2023 Add some static logs to check, maybe it is copy paste issue, use the copy button above my script. RE: Wrong password - admin - 19.10.2023 Daniel's code will only log existing normal users (not admin). This script will log only failed attempts for all users: Code: items = db:getall([[
SELECT *
FROM user_logs
WHERE failed=1
LIMIT 50
log(item.login, item.ip, item.created)
endRE: Wrong password - a455115 - 20.10.2023 (19.10.2023, 12:58)admin Wrote: Daniel's code will only log existing normal users (not admin). This script will log only failed attempts for all users:Hello admin, This script is functioning, but it logs full even when there is just one incorrect password attempt. Could you please explain what it does exactly? I want it to log only the actual instances of entering the wrong password. RE: Wrong password - Daniel - 20.10.2023 All logins are saved in DB and this script is just browsing the DB for all failed attempts. If you set limit to 1 it will give you only the last one but this is not an event action it is just pure reading what is in the DB. |
