Is it possible to integrate LM with AWS IoT as of 2023? - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Is it possible to integrate LM with AWS IoT as of 2023? (/showthread.php?tid=5050) |
Is it possible to integrate LM with AWS IoT as of 2023? - Hadeel - 24.10.2023 Hi! I have reviewed the thread below and understood we can place cert files of AWS IoT in LM, https://forum.logicmachine.net/showthread.php?tid=2223&highlight=aws+iot but is it possible to integrate LM with AWS IoT as of 2023? In my understanding, if we want LM to play a role as an AWS IoT device we need to install AWS IoT SDK which requires either of Node.js(version10+), Python(Version3.6+) or Java(version8) but is there any way possible to install it? FYR https://docs.aws.amazon.com/iot/latest/developerguide/iot-sdks.html Thank you so much in advance! RE: Is it possible to integrate LM with AWS IoT as of 2023? - admin - 24.10.2023 AWS IoT supports MQTT so you don't need any SDK to work with it. RE: Is it possible to integrate LM with AWS IoT as of 2023? - Hadeel - 05.11.2023 Thank you admin it is actually true. After you said so I tried and successfully connect LM with AWS IoT. : ) However I had a hard time placing the certificate files in LM. I wanted to store them in 'data/ftp' directory with FTP but when I use the sevice like Filezilla (Visual FTP tool) I could not find the 'data/ftp' directory and even though I tried placing the certificate files in other directory I could not reach them from the script. Is there a easier way to place the certificate files in LM? Like scp commands? RE: Is it possible to integrate LM with AWS IoT as of 2023? - admin - 06.11.2023 /data/ftp/ is the root directory for FTP server ftp login (not apps). If you upload client.crt into ftp root directory the absolute file path will be /data/ftp/client.crt RE: Is it possible to integrate LM with AWS IoT as of 2023? - Hadeel - 06.11.2023 Oh I see! I need to use "ftp" for the username to use the folder /data/ftp/. Can I use scp command to do the same thing? RE: Is it possible to integrate LM with AWS IoT as of 2023? - admin - 06.11.2023 You can only use FTP. RE: Is it possible to integrate LM with AWS IoT as of 2023? - Hadeel - 06.11.2023 OK : ) Thank you for your answer admin! |
