Problem in shutter vertical - Printable Version
+--- Thread: Problem in shutter vertical (/showthread.php?tid=5055)
Problem in shutter vertical - omarlachhab - 25.10.2023
 I have a problem with vertical shutter, the status feedback for height not working in Mosaic
Please any solution ?
RE: Problem in shutter vertical - admin - 26.10.2023
Manually update Mosaic app (via "Install from file" in the app store) and see if it fixes the issue for you.
Package file: https://dl.openrb.com/pkg/mosaic30-20231026.ipk
RE: Problem in shutter vertical - omarlachhab - 26.10.2023
(26.10.2023, 10:59)admin Wrote: Manually update Mosaic app (via "Install from file" in the app store) and see if it fixes the issue for you.
It works, thank you very much
