Lack of GA syncronisation - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Lack of GA syncronisation (/showthread.php?tid=5064) |
Lack of GA syncronisation - sck - 30.10.2023 Dear all, I have made some changes in group addresses in ETS 6 but all the logic machine group addresses are not syncing. To be more precise, the object name and data type are still the ´old ones´. Is there a way of syncing the group addresses? If I click on sync project data, nothing happens. THanks!!! RE: Lack of GA syncronisation - Daniel - 30.10.2023 While importing ETS project to LM existing groups will not be updated. If you changed objects in ETS you must delete them from LM first and then import. Sync project data has nothing to do with objects. RE: Lack of GA syncronisation - sck - 31.10.2023 (30.10.2023, 15:53)Daniel Wrote: While importing ETS project to LM existing groups will not be updated. If you changed objects in ETS you must delete them from LM first and then import. Sync project data has nothing to do with objects. THANKS! |
