1-wire on LM5lite with DS9490R dongle - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: 1-wire on LM5lite with DS9490R dongle (/showthread.php?tid=5065) |
1-wire on LM5lite with DS9490R dongle - robikozo - 30.10.2023 Hello, I would like to integrate 1-wire temperature, lux and humidity sensors into the LM5lite, can You explain how i can do it further? Maybe there is a way of reading values with a script or so? I really need a quick answer. Best Regards, Robertas Birgiolas’s RE: 1-wire on LM5lite with DS9490R dongle - admin - 31.10.2023 Check that you have 2023 firmware then install libow, owserver, luaow and genohm-scada-w1 packages from here: https://dl.openrb.com/lm-23-imx6/pkg/ Install through System config > System > Packages > Add package (green plus icon). RE: 1-wire on LM5lite with DS9490R dongle - a455115 - 31.10.2023 (31.10.2023, 07:55)admin Wrote: Check that you have 2023 firmware then install libow, owserver, luaow and genohm-scada-w1 packages from here: https://dl.openrb.com/lm-23-imx6/pkg/ Can other adapters be used for 1-wire? RE: 1-wire on LM5lite with DS9490R dongle - admin - 31.10.2023 Only DS9490R is supported over USB. RE: 1-wire on LM5lite with DS9490R dongle - robikozo - 02.11.2023 I ordered DS9490R, waiting for arival, after recieving it I will test it and tell You the results. Thanks |
