Mosaic RGBW widget cannot be controlled by cloud - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: Mosaic RGBW widget cannot be controlled by cloud (/showthread.php?tid=5085) |
Mosaic RGBW widget cannot be controlled by cloud - tpospichal - 07.11.2023 Hello I am not able to control RGBW widget on screenshot by cloud connection. Locally everything works, but remotely just this widget does not respond. Last version of firmware and apps. Thank you. RE: Mosaic RGBW widget cannot be controlled by cloud - Daniel - 08.11.2023 Which object do you use? RE: Mosaic RGBW widget cannot be controlled by cloud - tpospichal - 08.11.2023 (08.11.2023, 09:09)Daniel Wrote: Which object do you use?Hello it is RGBW dimmer 2 sliders (6 bytes Dali) RE: Mosaic RGBW widget cannot be controlled by cloud - Daniel - 09.11.2023 We tested it and works fine, are you sure you have all apps up to date also LM cloud app? RE: Mosaic RGBW widget cannot be controlled by cloud - tpospichal - 13.11.2023 (09.11.2023, 08:48)Daniel Wrote: We tested it and works fine, are you sure you have all apps up to date also LM cloud app? Now i tested RGBW Dimmer 1 slider (6bytes) and behavior is the same. No controll by cloud. I have everything updated.... I also have the problem, that 6bytes objects cannot be imported from esf file i have to create them manulally in LM.... RE: Mosaic RGBW widget cannot be controlled by cloud - Daniel - 13.11.2023 Import ETS project instead of esf. As we can't re-create your issue send me your backup to PM. RE: Mosaic RGBW widget cannot be controlled by cloud - tpospichal - 13.11.2023 (13.11.2023, 09:21)Daniel Wrote: Import ETS project instead of esf. Already sended. Thanks RE: Mosaic RGBW widget cannot be controlled by cloud - Daniel - 13.11.2023 Your backup works fine for me, had to change the status object as don't have live device so just used same object as control. Synced to my cloud account and works. Maybe make some video to show exactly what is not working. Log also the objects to see if all is received a specially the feedback. PS. in your backup you used different widget than the photos above. |
