Clear the Alert page from the visualization - Printable Version
+--- Thread: Clear the Alert page from the visualization (/showthread.php?tid=509)
Clear the Alert page from the visualization - cekca - 13.12.2016
there is a way to clear the alert page from visualization...???
maybe with a POST method..???
RE: Clear the Alert page from the visualization - Erwin van der Zwart - 13.12.2016
Hi Cekca,
Here is a post command to clear the alerts, it sends same command when pushing the button on the backend.
require('json') require('socket.url') require('socket.http') fields = {  alerts = true, } data = json.encode(fields) post = 'data=' .. socket.url.escape(data) ip = '127.0.0.1' username = 'admin' password = 'admin' res, err = socket.http.request('http://' .. username .. ':' .. password .. '@' .. ip .. '/scada-main/general/reset', post) log(res, err)
RE: Clear the Alert page from the visualization - cekca - 14.12.2016
Thank you Erwin...
After the reset is possible to force the reload of the alerts page...??? i don't want to wait the refresh of the frame.
Marco
RE: Clear the Alert page from the visualization - Erwin van der Zwart - 14.12.2016
Hi Marco,
Yes can be done but not simple..
Refresh is client side, so you must attach a listener to your button with custom javascript and make a function to find your iframe and perform the reload in that frame.
Can you do that?
no problem, i'll reduce the refresh time of the frame...
RE: Clear the Alert page from the visualization - PassivPluss - 01.02.2017
I tried this script earlier but it was not working. Can anyone of you post a picture of how the page will look when it is made. I need to use an alert page in a project and it would be nice to see it Smile
RE: Clear the Alert page from the visualization - CHOUAIBOU - 02.02.2017
(01.02.2017, 21:26)PassivPluss Wrote: I tried this script earlier but it was not working. Can anyone of you post a picture of how the page will look when it is made. I need to use an alert page in a project and it would be nice to see it Smile
Hi PassivPluss,
The page will be blank (without any alert message)
RE: Clear the Alert page from the visualization - Erwin van der Zwart - 02.02.2017
I have created a alert app for this, and send it to EMBS for appstore. I have no idea what the status is for publishing and if they are planning to publish it..
See screenshot (:
RE: Clear the Alert page from the visualization - buuuudzik - 02.02.2017
Nice screen and for sure nice appWink
RE: Clear the Alert page from the visualization - cekca - 02.02.2017
AMAZING..!!! When will be available...??? Tongue
RE: Clear the Alert page from the visualization - edgars - 02.02.2017
we will adjust and place the app in the store very soon.
RE: Clear the Alert page from the visualization - edgars - 03.02.2017
Alerts Manager can be already downloaded from app store.
RE: Clear the Alert page from the visualization - Erwin van der Zwart - 03.02.2017
(03.02.2017, 13:11)edgars Wrote: Alerts Manager can be already downloaded from app store.
Please wait or update again later, Edgars used a old version (oeps i probably never send latest version sorry)
New version is on it's way!
RE: Clear the Alert page from the visualization - emdolivier - 05.07.2019
Is there a script that we can sent a acknowledge
RE: Clear the Alert page from the visualization - Erwin van der Zwart - 05.07.2019
Yes you can do that with custom JS (in this sample by bit object with address 1/1/1) and used in a iframe:
$(function(){  $(document).ready(function() {          var f= $('iframe');    f.load(function(){      if (typeof grp != 'undefined') {           grp.listen('1/1/1', function(object, state) {             if (state == 'value' && object.value == true ){                f.contents().find('#AcknowledgeButton').click();             }          }, true);      }      });   }); });
