Mosaic inline frame doesn't show scheduler - Printable Version
+--- Thread: Mosaic inline frame doesn't show scheduler (/showthread.php?tid=5098)
Mosaic inline frame doesn't show scheduler - Zen - 17.11.2023
Hi everyone,
we are testing out a way to show LogcMachine Schedulers in Mosaic.
Here in the forum, i found somewhere that you can use a simple inline frame with the correct directory to show data on the widget. I've done this writing "/scada-vis/schedulers" on the URL field of the inline frame widget.
That way works perfectly until i'm in the same network as the LM is.
When i try to connect remotely via my LogicMachine app on my phone, on my iPhone the widget doesn't show anything, on Android it tells me that the webpage is not available cause i'm trying to connect to "https://remote.logicmachine.net/scad-vis/schedulers" and that resource doesn't exists.
Is there any other way to link Schedulers on Mosaic or solve this redirect trouble?
Thank you for further help.
RE: Mosaic inline frame doesn't show scheduler - CristianAgata - 17.11.2023
(17.11.2023, 15:27)Zen Wrote: Hi everyone,
In mosaic there's a separate app. If you press X in the right to you can access at the app schedule.
Best regards Cristian
RE: Mosaic inline frame doesn't show scheduler - Zen - 21.11.2023
Thank you, solved. I had the close button deactivated so i didn't mind to check it before write. Thank you!
