Connection from different NET - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Hardware (https://forum.logicmachine.net/forumdisplay.php?fid=12) +--- Thread: Connection from different NET (/showthread.php?tid=5103) |
Connection from different NET - Frank68 - 21.11.2023 Greetings I would need to be able to access the LM from different subnets: 192.168.1.n 192.168.2.n I tried to change the subnet to 255.255.252.0 but to no avail, is there something in the LM that blocks access from different networks? RE: Connection from different NET - forsterm - 21.11.2023 See this: https://forum.logicmachine.net/showthread.php?tid=2595&pid=16682#pid16682 (21.11.2023, 08:06)Frank68 Wrote: Greetings RE: Connection from different NET - Frank68 - 21.11.2023 (21.11.2023, 08:11)forsterm Wrote: See this: https://forum.logicmachine.net/showthread.php?tid=2595&pid=16682#pid16682 I not ned more LM on the net i need more computer from different net able to connect to the same LM, i have the vlan but is all open. RE: Connection from different NET - admin - 21.11.2023 This has to be configured on your router. Make sure that LM has a correct gateway set. Keep netmask as 255.255.255.0. RE: Connection from different NET - Frank68 - 22.11.2023 (21.11.2023, 13:39)admin Wrote: This has to be configured on your router. Make sure that LM has a correct gateway set. Keep netmask as 255.255.255.0. Hi, I have the corret SN and GW , but nothing, is not possible to reach the LM from different network, if I set more I, IN the LM I use Zerotier for remote connection and if i set more IP ZeroTier not work. how can I solve it ? Thank's RE: Connection from different NET - admin - 22.11.2023 Having an extra IP address should not affect ZeroTier unless you have the same network on both eth0 and virtual ZeroTier interface. If you have several subnets on the same LAN then you should be able to connect to LM using both IP addresses. Of course, the connecting device should also belong to the same subnet. If subnets are not different LANs then your router must be configured to accept and route traffic between these subnets. In this case LM does not need an extra IP address. |
