Change the value of Modbus register with KNX Group address - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Change the value of Modbus register with KNX Group address (/showthread.php?tid=5114) |
Change the value of Modbus register with KNX Group address - Samer - 26.11.2023 hello Guys. I have been facing a problem with changing the value from modbus .controlling set point temperatures through group address 1/1/1 I can read, and write the value, However, when I send for example 1 the output on the AC thermostat is 16, 2 the output is 17 ..... I found that from modbus side from 1-17 and from knx 16-32 any help for the script ??? RE: Change the value of Modbus register with KNX Group address - CristianAgata - 26.11.2023 (26.11.2023, 17:37)Samer Wrote: hello Guys. Hi, Check this file https://openrb.com/docs/modbus.htm If you're using json file I think that you can do it with this: "value_base" : 15 Best regards Cristian |
