LTE ANTENNA - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Hardware (https://forum.logicmachine.net/forumdisplay.php?fid=12) +--- Thread: LTE ANTENNA (/showthread.php?tid=5124) |
LTE ANTENNA - Frank68 - 30.11.2023 HI How much can I extend the antenna in the LTE reactor? What specifications should the cable have? Thank you RE: LTE ANTENNA - admin - 30.11.2023 Cable length depends on the cable type. For example RG58 cable length is around 6 meters. Note that a longer cable produces higher signal loss so in the end you might get worse signal by placing the antenna higher but having a longer cable. |
