Stability issue - Printable Version
+--- Thread: Stability issue (/showthread.php?tid=5128)
Stability issue - emme - 03.12.2023
After installing 2023.06 upgrade on mu LM5 lite (i.Mx6 3din) I've seen BLE tag has disappear
so I reinstall libbluetooth_5.64-1 and its signature.... then reboot and LM keeps on crash and reboot
I had a 2minutes window in whitch I can enter package and remove libbluetooth_5.64-1 to get system stable again.....
is anyone facing the same issue?
RE: Stability issue - admin - 04.12.2023
We've tested this locally and can't reproduce this issue.
Add the following code to init script:
io.writefile('/proc/sys/kernel/panic', 0) io.writefile('/proc/sys/kernel/panic_on_oops', 0)
This should prevent LM from rebooting if BLE driver crashes. Then install all BLE packages back and provide the logs that you get in System config > Status > System log.
