SL 2.8.2 backup import in to higher version - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: SL 2.8.2 backup import in to higher version (/showthread.php?tid=5129) |
SL 2.8.2 backup import in to higher version - khalil - 04.12.2023 Hello Dears, I want to import 2.8.2 SL backup in to 2.8.3 version it gives me backup file is invalid! how to overcome this issue! if downgrade is a solution then I need the signature file for 2.8.2. RE: SL 2.8.2 backup import in to higher version - Daniel - 04.12.2023 There is no issue between backups compatibility, when you see this message it could be that backup is password protected. RE: SL 2.8.2 backup import in to higher version - khalil - 04.12.2023 (04.12.2023, 08:54)Daniel Wrote: There is no issue between backups compatibility, when you see this message it could be that backup is password protected. Thank you, you are right. It will be good to have a password warning instead of general one! RE: SL 2.8.2 backup import in to higher version - Erwin van der Zwart - 04.12.2023 This is already changed in the translations and will be added/changed in the next FW update. RE: SL 2.8.2 backup import in to higher version - khalil - 04.12.2023 (04.12.2023, 09:05)Erwin van der Zwart Wrote: This is already changed in the translations and will be added/changed in the next FW update. Great |
