My Problem with firmware - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Hardware (https://forum.logicmachine.net/forumdisplay.php?fid=12) +--- Thread: My Problem with firmware (/showthread.php?tid=5133) |
My Problem with firmware - Patrik1985 - 06.12.2023 hello My sd-card has give up, so i bought a new one and now i have problem to instal the firmware. I instal the recovery.img.gz, its woking but i cant install the firmware Wiser_for_knx-2.8.0_HW1 and i have treid the 2.8.3 Its says Bad Gateway its a lss100100 v1.3 RE: My Problem with firmware - Erwin van der Zwart - 06.12.2023 Clear browser cache (as always when experience strange behaviour) RE: My Problem with firmware - admin - 06.12.2023 Try this recovery image: https://dl.openrb.com/recovery-mxs-1g.img.gz Most likely you have an old recovery with 16MB file limit. Newer firmware is larger so it's not accepted. Another solution is to install older firmware first, just make sure that image size is less than 16MB. RE: My Problem with firmware - Patrik1985 - 06.12.2023 (06.12.2023, 09:57)admin Wrote: Try this recovery image: https://dl.openrb.com/recovery-mxs-1g.img.gz Thank you, its working. Is it possible to rescue something from the old memorycard? i have some script that i should be happy to bring back
RE: My Problem with firmware - admin - 07.12.2023 You can try making a disc image of the whole SD card an open it with 7-zip. If it works then find storage/current.db or storage/db/current.db on the last partition (marked as 2.img). If this file is not corrupt then you can open it with DB Browser for SQLite. Scripts are stored in scripting table. RE: My Problem with firmware - Patrik1985 - 07.12.2023 (07.12.2023, 10:03)admin Wrote: You can try making a disc image of the whole SD card an open it with 7-zip. If it works then find storage/current.db or storage/db/current.db on the last partition (marked as 2.img). If this file is not corrupt then you can open it with DB Browser for SQLite. Scripts are stored in scripting table. Amazing! i see it all, thank you very much!
