Get time and date from KNX to LM - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Get time and date from KNX to LM (/showthread.php?tid=5163) |
Get time and date from KNX to LM - savaskorkmaz - 19.12.2023 Hi, There is an example about how we can write LM's time and date to group address. But i need a revers example. I wan to read from KNX group address and write to LM's date and time. Do you have an example ? Regards, RE: Get time and date from KNX to LM - Daniel - 19.12.2023 The correct way is to use NTP as if you use the script from link below you will make jump in time and if a schedule event happen in the meantime you will miss the event. https://openrb.com/example-change-timedate-from-lua-script-on-lm2/ |
