variable value lost sometimes - Printable Version
+--- Thread: variable value lost sometimes (/showthread.php?tid=5165)
variable value lost sometimes - Osvaldas - 20.12.2023
I have encountered an issue where the script section responsible for heat pump cooling sometimes runs unexpectedly, even though the conditions for its execution are not met. By using the log function, I identified that the variable `holas = '3/0/1'` activated this script, despite no conditions being met to proceed with the script. Upon  checking the log, I noticed that the variable `thermostat_Heating_Cooling` was holding the value 1, indicating that it shouldn't proceed with the script execution.
Is it possible for variables to lose their value at times?
The addresses listed have assigned tags that can trigger the script
holas = '3/0/1'
svetainė = '3/0/3'
kambario = '3/0/4'
miegamojo = '3/0/5'
vonia = '3/0/6'
thermostat_Heating_Cooling = '3/6/20'
sildymas_siurb_arba_centrin = '6/1/13'
sil_siurb_heat_seatpoint = '11/1/16'
sil_siurb_cool_seatpoint = '11/1/15'
trieigio_PID_enabled_disabled = '3/5/20' sil_siurb_onoff = '11/1/21' sil_siurb_cool_heat = '11/1/20' sil_siurb_cool_heat_setpoint = '11/1/3' sil_siurb_heat_seatpoint = '11/1/16' sil_siurb_cool_seatpoint = '11/1/15' dv1_voztuvas = '4/5/13' dv2_voztuvas = '4/5/14' srb1_cirkuliacinis = '4/5/11' srb2_cirkuliacinis = '4/5/12' sildymas_siurb_arba_centrin = '6/1/13' esamas_klimato_rezimas = '6/1/7' thermostat_Heating_Cooling = '3/6/20' holas = '3/0/1' svetainė = '3/0/3' kambario = '3/0/4' miegamojo = '3/0/5' vonia = '3/0/6' adresas = event.dst --************************Debugging********************************* local function logEventWithAddress(event, address)     log("Event triggered by address " .. address .. ": " .. event) end --*********************Valve control - central heating************************************** if adresas == sildymas_siurb_arba_centrin or adresas == thermostat_Heating_Cooling then   if  not grp.getvalue(sildymas_siurb_arba_centrin)        and grp.getvalue(thermostat_Heating_Cooling)      then            grp.checkwrite (sil_siurb_cool_heat, true)        os.sleep(1)     grp.checkwrite (srb1_cirkuliacinis,true)                grp.checkwrite (sil_siurb_onoff, false)     grp.checkwrite (dv1_voztuvas,true)     grp.checkwrite (dv2_voztuvas,false)      grp.checkwrite (trieigio_PID_enabled_disabled, false)     logEventWithAddress("Valve control - Central heating", adresas)   end end --*********************Valve control - Heat pump heating************************************** if adresas == sildymas_siurb_arba_centrin or adresas == thermostat_Heating_Cooling then   if grp.getvalue(sildymas_siurb_arba_centrin)      and grp.getvalue(thermostat_Heating_Cooling)    then         grp.checkwrite (sil_siurb_cool_heat, true)    os.sleep(1)   grp.checkwrite (srb1_cirkuliacinis,false)    grp.checkwrite (sil_siurb_onoff, true)        grp.checkwrite (dv1_voztuvas,false)    grp.checkwrite (dv2_voztuvas,true)    grp.checkwrite (trieigio_PID_enabled_disabled, true)    logEventWithAddress("Valve control - Heat pump HEATING", adresas)   end end --*********************Valve control - Heat pump cooling************************************** if not grp.getvalue(thermostat_Heating_Cooling)     then       grp.checkwrite (sil_siurb_cool_heat, false)    os.sleep(1)   grp.checkwrite (sil_siurb_onoff, true)      grp.checkwrite (srb1_cirkuliacinis,false) -- SRB1 OFF   grp.checkwrite (dv1_voztuvas,false)    grp.checkwrite (dv2_voztuvas,true)    grp.checkwrite (trieigio_PID_enabled_disabled, true)   logEventWithAddress("Valve control - Heat pump COOLING", adresas)   end
RE: variable value lost sometimes - admin - 20.12.2023
Which firmware version do you have?
RE: variable value lost sometimes - Osvaldas - 21.12.2023
(20.12.2023, 16:16)admin Wrote: Which firmware version do you have?
Firmware version is 2022/12/05
RE: variable value lost sometimes - admin - 22.12.2023
Install 2023 firmware.
RE: variable value lost sometimes - Osvaldas - 22.12.2023
(22.12.2023, 08:50)admin Wrote: Install 2023 firmware.
Thank you for your suggestion.
I've never noticed such a thing before. Just out of curiosity, is it a known bug or something?"
It's a rare bug that was fixed in 2023 RC2: https://forum.logicmachine.net/showthread.php?tid=4572&pid=29578#pid29578
(22.12.2023, 09:01)admin Wrote: It's a rare bug that was fixed in 2023 RC2: https://forum.logicmachine.net/showthread.php?tid=4572&pid=29578#pid29578
Thank you   Smile
