BACNET functionality - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: BACNET functionality (/showthread.php?tid=5168) |
BACNET functionality - Lumite - 21.12.2023 Hello, Thanks for allowing me to this forum. I am currently busy with a BACNET->ModbusTCP gateway application. I did have a running HomeLYnk for this, but the SD card got defect. Now I have a new HomeLynk (Wiser for KNX) and I'm trying to rebuild the application. The main problem I face right now is: The BACnet Library is not installed on the wiser. I copied all the BACNet related files from the Homelynk to the same positions on the Wiser SD, but that is not working. Can anyone please supply me with the right files and procedures to get the BACNet library working on the Wiser? The issue is the 3rd partition on the SD-card, it couldn't be recoverd. Then the next question, the user-build scripts, where can I find them on the SD-Card? thanks in advance! Update: I think I found the right package in another threat, I found a bacnet.idk link! I will try to install this one. best regards Ivo Warmels RE: BACNET functionality - Daniel - 21.12.2023 Bacnet server is out of the box on W4K no need to mess with it. If you need Bacnet Client then on SE store there is app for it. RE: BACNET functionality - Lumite - 21.12.2023 (21.12.2023, 12:36)Lumite Wrote: Hello, Unforunately the installation of the package did not work. This is the information form the error-Log: BacNet_GW 21.12.2023 14:13:06 error loading module 'bacnet' from file 'Library bacnet': Library bacnet:1: unexpected symbol stack traceback: [C]: at 0x00055100 [C]: in function 'require' RE: BACNET functionality - Daniel - 21.12.2023 W4K does not support what LM has, stick to default solutions what SE provides. RE: BACNET functionality - Lumite - 21.12.2023 (21.12.2023, 13:19)Daniel Wrote: W4K does not support what LM has, stick to default solutions what SE provides. OK, I will investigate. Hope my script still will work with this device ![]() This is the basics of the script in the LM: value = bacnet.readvalue(2457601, 'analog input',12) value = float2hex(value) mb1 etregisters(24, lmcore.hextoint(string.sub(value,1,4)))mb1 etregisters(25, lmcore.hextoint(string.sub(value,-4)))Now I need to find an equivalent of the bacnet.readvalue function RE: BACNET functionality - Daniel - 21.12.2023 As mentioned above, install bacnet client app from SE store. RE: BACNET functionality - Lumite - 21.12.2023 (21.12.2023, 13:35)Daniel Wrote: As mentioned above, install bacnet client app from SE store. at this location I do not have internet access for the W4K, so I installed the bacnetclient ipk I mentioned above... |
