Modbus: Readtest - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Modbus: Readtest (/showthread.php?tid=5174) |
Modbus: Readtest - Amelie - 26.12.2023 I have a modus connection with my Goodwe inverter, but I often get the fault: invalid data. So, I'm looking around what I'm doing wrong. When I perform 10 read tests in a row, I get 9 times a result ( a succes). But once in a while, I get the error: invalid data. (I didn't change anything to the setting. The only thing I can think of is that I perform the read test to soon after each other, and that the LM or the inverter is still busy. Or, can there be an other cause of this behaviour? RE: Modbus: Readtest - Erwin van der Zwart - 27.12.2023 I assume you are talking about a IP connection? If yes it’s probably that the remote device supports a certain number of connections (often 1 or 5) and the connection is closed after a certain timeout and becomes available for a new connection. In this scenario you should check “Persistent connection” in the device connection settings. |
