dali - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: dali (/showthread.php?tid=5178) |
dali - abby - 02.01.2024 I have a dali 2 sensor with 2 light attach to it i want to control through lm5 is it possible to control it RE: dali - admin - 02.01.2024 Which sensor are you using? RE: dali - abby - 02.01.2024 (02.01.2024, 08:39)admin Wrote: Which sensor are you using? Dali PIR + light sensor and its is power supply by dali bus RE: dali - Daniel - 02.01.2024 Which sensor are you using? RE: dali - abby - 02.01.2024 SR-DA9030A-PIR RE: dali - admin - 02.01.2024 Which LM DALI solution are you using? CANx-DALI or old DALI tab in the LM main interface? RE: dali - abby - 09.01.2024 (02.01.2024, 09:51)admin Wrote: Which LM DALI solution are you using? CANx-DALI or old DALI tab in the LM main interface? CANx-dali ONE RE: dali - admin - 09.01.2024 CANx-DALI app with DALI2 support will be published soon. But it will only support what is defined in DALI standards (IEC62386 301/302/303/304) and some Lunatone sensors. RE: dali - rw_echo - 29.01.2024 Sorry, take up a post, Admin, LM_ How to resolve the device address conflict on DR's DALI bus, or how to clear the device address on the DALI bus and rescan the address RE: dali - admin - 29.01.2024 Perform "Set short addresses" and it will reset the addressing for the whole bus. RE: dali - rw_echo - 29.01.2024 I have tried multiple times to reassign device short addresses through 'Full scan, set short addresses', but have not been successful. I plan to clear all device addresses and reset them through a script. Can you provide a complete script example? RE: dali - admin - 29.01.2024 If addressing is not working correctly then there's something wrong with the bus and/or ballasts that do not adhere to the DALI standard. You can clear all addresses via a script like this: Code: require('user.dali')
dalicmd('internal', 'setdtr', { addrtype = 'broadcast', value = 255 })
dalicmd('internal', 'storeshortaddress', { addrtype = 'broadcast' })CANx-DALI version: Code: canxdali = require('applibs.canxdali')
canxdali.sendcmds({
lineid = 0,
nodeid = 30,
cmds = {
{ cmd = 'setdtr', address = 'broadcast', value = 255 },
{ cmd = 'storeshortaddress', address = 'broadcast' }
})RE: dali - rw_echo - 29.01.2024 Is the LM script with built-in DALI interface like this? require('user.dali') dalicmd('internal', cmd = 'setdtr', address = 'broadcast', value = 255) dalicmd('internal', 'storeshortaddress', address = 'broadcast) RE: dali - admin - 29.01.2024 Check my previous post, it has examples for both types of DALI interface. RE: dali - rw_echo - 29.01.2024 Awkwardly, could you please support writing an example of reallocating all device addresses through a script. RE: dali - admin - 29.01.2024 Check this: https://forum.logicmachine.net/showthread.php?tid=2147&pid=13433#pid13433 |
