GROUP BUS RECORD - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: GROUP BUS RECORD (/showthread.php?tid=5179) |
GROUP BUS RECORD - j.martinez@t-ingeniamos.com - 02.01.2024 Hello there, Is there any script or plug to record the group monitor bus traffic? We just need to check what is happening in the group monitor several days and thinking if is possible to record them into the LM to check them later. Kind Regards, RE: GROUP BUS RECORD - CristianAgata - 02.01.2024 (02.01.2024, 13:30)j.martinez@t-ingeniamos.com Wrote: Hello there, Hi, Check the box in the object (recording). You can increase the log number in setting (untill 50000 record if I don't make mistakes) Best regards Cristian RE: GROUP BUS RECORD - Daniel - 02.01.2024 If you log a object it will record all values for this object. There is Group monitor app but it will show only telegrams as long as you keep the app open. RE: GROUP BUS RECORD - j.martinez@t-ingeniamos.com - 02.01.2024 Thank you Daniel and Cristian i will try it. |
