Bacnet stopped working - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Bacnet stopped working (/showthread.php?tid=5189) |
Bacnet stopped working - harald.kjaerre@tratec.no - 05.01.2024 Did anyone ever experience that BACnet stopped working? Everything else works as normal, but the LM5 lite stopped sending and recieving BACnet objects. Did try reset, powercycle, firmwareupdate, enable/disable BACnet server. its no longer reachable by YABE WEB page works normally, KNX objects are updated both ways RE: Bacnet stopped working - admin - 05.01.2024 After performing factory reset have you tried running BACnet server with a single exported object (without restoring the backup)? Maybe there's some specific configuration in your backup that prevents the server from running. RE: Bacnet stopped working - Daniel - 05.01.2024 Try changing bacnet ID, maybe there is a conflict. |
