RGBW control WIDGET - Printable Version
+--- Thread: RGBW control WIDGET (/showthread.php?tid=5193)
RGBW control WIDGET - Hosutech - 07.01.2024
happy New Year to everyone!
I'm working on a project where I'm asked to manage RGBW, I managed to propose a solution to the client using the "12,600 colors RGBW" type object. The customer asks me if it is possible to keep the widget open until he finds the right color for the lighting of a room instead of having to open it every time he sends the color chosen from the palette. Could you change this object so that it only closes when you select the "x"?
RE: RGBW control WIDGET - admin - 08.01.2024
Enable "Send after each color pick" in Vis. parameters.
