turn lights with double pulse in a switch - Printable Version
+--- Thread: turn lights with double pulse in a switch (/showthread.php?tid=5200)
turn lights with double pulse in a switch - JoseJimenez94 - 12.01.2024
Hi guys,
I have been testing our colleague's solution (https://forum.logicmachine.net/showthread.php?tid=31&highlight=count+pulse) to be able to turn on two different lights with the same button using a single pulse or double pulse, but I can't get it to work properly (and I don't know if there is something I haven't understood well)
I have created a resident script (sleep interval 0), where the address 16/1/1 is the press that I make on the button, the addresses 1/1/10 and 1/1/120 are the lights and the address 16/1/2 is an address that I have created to perform the count
if not client then   require('genohm-scada.eibdgm')     -- knx group write handler   function groupwrite(event)     local value     value = knxdatatype.decode(event.datahex, dt.bool)     --first room     if event.dst == "16/1/1" then       switcher("16_1_1", "1/1/10", "1/1/120", "16/1/2", value)     end   end     client = eibdgm:new()   client:sethandler('groupwrite', groupwrite)   function switcher(event_adress, light1, light2, counter_object, value)     nowTIME = os.time()     counter = grp.getvalue(counter_object)     state = value     if (state == false) then       counter = counter + 1       log(counter)       lastONtime = storage.get('lastONtime' .. event_adress)       if (nowTIME - lastONtime > 1) then         log('long press ' .. event_adress)         grp.write(light1, false)         grp.write(light2, false)         grp.update(counter_object, 0)       else         grp.update(counter_object, counter)       end     else       storage.set('lastONtime'  .. event_adress, nowTIME)     end      end end client:step()
And also at address 16/1/2 I have created the following event script:
value = tonumber(event.datahex, 16) if value > 0 then   light1 = '1/1/10'   light2 = '1/1/120'   switcher_adress = '16/1/1'   os.sleep(1)   value = event.getvalue()   if value == 1 then     log('single press '.. switcher_adress)     grp.write(light1, not(grp.getvalue(light1)))   elseif value == 2 then     log('double ' .. switcher_adress)     grp.write(light2, not(grp.getvalue(light2)))   end   -- reset counter   if value > 0 then     grp.update(event.dst, 0)   end end
The problem is that I can't get it to turn on the corresponding lights by giving it a single pulse or two, but nevertheless there are times when I do a short press, it interprets that I have done a long press and turns off the lights or when I try to do a double press , it interprets that I have done one or that I have done a long press (that is, it does different things each time). I can't find what the problem is.
I hope you can help me. Thank you so much
RE: turn lights with double pulse in a switch - admin - 12.01.2024
See this: https://kb.logicmachine.net/scripting/single-double-press/
