Thresholds - Printable Version
+--- Thread: Thresholds (/showthread.php?tid=5206)
Thresholds - Bergman - 17.01.2024
I have a humidity sensor with no threshold options, it only sends humidity on change.
I also have a dimmer which controls a fan and I want to control the fan with value depending on humidity level.
In 2 or 3 steps/thresholds.
Have been searching the forum but cannot find any similar, perhaps im using the wrong keywords.
Anyone who can give me a tip on what to use?
Regards,
Peter
RE: Thresholds - RomansP - 17.01.2024
HI Bergman
I am not sure that it is exactly what you need, but have a try,
and please give me feedback.
This code is for humidity scale object (event script).
local humidity = event.getvalue() -- scale object local fan_addr = '38/1/26' -- scale object local fan_val_level_1 = 30 -- values for scale object local fan_val_level_2 = 60 local fan_val_level_3 = 100 if humidity < 33 then -- humidity less than 33%   grp.write(fan_addr, fan_val_level_1) elseif humidity > 38 and humidity < 66 then -- 38% < humidity < 66%   grp.write(fan_addr, fan_val_level_2) elseif humidity > 71 then -- humidity more than 71%   grp.write(fan_addr, fan_val_level_3) end
Regards,
Romans
Here is updated version of the script.
local humidity = event.getvalue() -- scale object local fan_addr = '38/1/26' -- scale object local fan_val_level_1 = 30 -- values for scale object local fan_val_level_2 = 60 local fan_val_level_3 = 100 local hyst = 5 -- 5% humidity hysteresis local hum_level_1 = 33 -- 33% humity local hum_level_2 = 66 -- 66% humidity if humidity < hum_level_1 then -- humidity less than 33%   grp.write(fan_addr, fan_val_level_1) elseif humidity > hum_level_1 + hyst and humidity < hum_level_2 then -- 38% < humidity < 66%   grp.write(fan_addr, fan_val_level_2) elseif humidity > hum_level_2 + hyst then -- humidity more than 71%   grp.write(fan_addr, fan_val_level_3) end
RE: Thresholds - Bergman - 17.01.2024
Thank you RomansP!
I think I can use alot of that to make my own newbie-script work.
You start off with "Local", what/how does that do/work? I haven't used that or read about it so far.
Regards,
Peter
RE: Thresholds - RomansP - 18.01.2024
In Lua, variables can be either local or global, and their scope determines where they can be accessed.
If before variable is local - means variable is local, if before variable is nothing it means variable is global.
Here is a pretty good summary about lua.
https://learnxinyminutes.com/docs/lua/
But you also can use chatGPT to improve your coding and ask some questions about code.
Regards,
Romans.
