SOAP - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: SOAP (/showthread.php?tid=532) |
SOAP - Thomas - 02.01.2017 Hi Is there a soap library available for Lua scripting? Or any other way how to call SOAP procedure on a remote server? Thank you RE: SOAP - admin - 02.01.2017 You can try adding LuaSOAP as user libraries with some minor modifications. 1. Create user library called lxplom and paste code this code: https://github.com/LuaDist/luaexpat/blob/master/src/lxp/lom.lua 2. Create user library called soap and paste code this code, replacing require"lxp.lom" with require"user.lxplom" https://github.com/tomasguisasola/luasoap/blob/master/src/soap.lua 3. Create user library called soapclient and paste code this code, replacing require("soap") with require("user.soap") https://github.com/tomasguisasola/luasoap/blob/master/src/client.lua Then in your script you can load client library like this: Code: client = require('user.soapclient')RE: SOAP - Thomas - 02.01.2017 Perfect. It works! Thank you |
