SOMETHING STRANGE - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Hardware (https://forum.logicmachine.net/forumdisplay.php?fid=12) +--- Thread: SOMETHING STRANGE (/showthread.php?tid=5327) |
SOMETHING STRANGE - Frank68 - 28.03.2024 Greetings a strange thing is happening to me, I'm connected remotely to an LM5 via Zerotier, I get to the web page but ETS doesn't see any device on the TP line, I updated the LM firmware this morning with version 2024, what could it depend on? Thank you very much RE: SOMETHING STRANGE - Daniel - 28.03.2024 Did you select, allow global IPs? RE: SOMETHING STRANGE - Frank68 - 28.03.2024 (28.03.2024, 12:34)Daniel Wrote: Did you select, allow global IPs? WHERE ? RE: SOMETHING STRANGE - Daniel - 28.03.2024 https://kb.logicmachine.net/misc/zerotier/ 13 RE: SOMETHING STRANGE - Frank68 - 05.04.2024 (28.03.2024, 12:41)Daniel Wrote: https://kb.logicmachine.net/misc/zerotier/ HI I set everything as on the other systems but there is something strange. via zerotier I connect to the LM without problems LM tells me TP bus OK, I do a line scan I see activity increase on LM but then ETS5 doesn't find any devices. All I have to do is try to go to the system, is port 3671 the only one used by ETS for programming? Thank you RE: SOMETHING STRANGE - Daniel - 05.04.2024 I just tested zerotier on 2024 fw and it works fine, was able to do a download, scan, ping, reset. The only thing which doesn't work is Device info read. For tunneling this port is used, did you select NAT? |
