Error in LM App Android/IOs - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Application Store (https://forum.logicmachine.net/forumdisplay.php?fid=11) +--- Thread: Error in LM App Android/IOs (/showthread.php?tid=5340) |
Error in LM App Android/IOs - Morpheus09 - 04.04.2024 I have an issue with the LM app, when I try to open mosaic thorugh cloud. there is a spinner that never stops, and after a few minutes logs out. Here is a Video showing the issue. https://drive.google.com/file/d/1Ws0E2u434cvSfd8wRcbzHMA5Nvipc3ih/view?usp=sharing RE: Error in LM App Android/IOs - CristianAgata - 04.04.2024 (04.04.2024, 16:49)Morpheus09 Wrote: I have an issue with the LM app, when I try to open mosaic thorugh cloud. Hi, Which is it your firmware? If you are running the 2024.02, try with LM Home Br Cristian RE: Error in LM App Android/IOs - Daniel - 04.04.2024 The spinner is a refresh when websocket connection is not established. Check if you see the same via normal browser. https://remote.logicmachine.net/user PS there is new app LM Home https://forum.logicmachine.net/showthread.php?tid=5220 RE: Error in LM App Android/IOs - Morpheus09 - 05.04.2024 I updated the Firmware to 2024.02, and now works fine. With both apps. (04.04.2024, 17:07)CristianAgata Wrote: Hi, The issue did not happen on a browser. only on the app. (04.04.2024, 17:10)Daniel Wrote: The spinner is a refresh when websocket connection is not established. Check if you see the same via normal browser. Thanks. RE: Error in LM App Android/IOs - Daniel - 05.04.2024 What firmware do you use? Is the LM cloud app up to date? What about Mosaic? What is the device you are testing on? |
